suspension problems...any help appriciated.
Ok here the deal my front right side(pass side) suspension makes a "creeky" noise usualy only when Im going slow (5mph) and turning right. I do have new struts and springs. Nothing is rubbing that I can see. Everything was installed correctly. From what Ive checked the cv is still good. Its definatley a creeky noise and not a clank that a cv makes. It doesnt seem noticeable at regular driving speeds just in parking lots while turing right I hear this annoying noise as the suspension compresses. Any bushings I should check? Is it possible that if I spray some wd40 near the moving parts that it might help? Is silicone and wd40 bad for bushings?
Ok I just drove it and it also will make the creek noise if im parked and just try turning the wheels left or right a lil. Would a worn ball joint make this noise?
Would power steering make this noise as well?
Modified by MulletManRockStar at 9:26 PM 3/5/2005
Modified by MulletManRockStar at 11:26 AM 3/6/2005
crxsleeper210
05-22-2020 02:46 PM
GagnarTheUnruly
07-26-2011 02:51 PM
alphalanos
09-26-2007 05:21 PM
