Need help with dash lights
Old 03-06-2005, 08:27 PM
Basically's Avatar
Default Need help with dash lights
My dash lights arent working(they didnt work when i bought the car). I have a 93 coupe. The only things that dont light up are the speedo, tach., etc. and the lights behind my climate control crap(the sliding things)....blinkers work the climate control buttins light up and all my little lights in the dash work, seatbelt, CEL, etc. its not the fuse, could it be the dummer switch???? TIA
Old 03-06-2005, 08:34 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: Need help with dash lights (FlatCivic)
It is the dimmer switch. Pull it out and you'll see that it's attached to a 3 wire plug. Try and wiggle each wire around and see if it lights up. It might be a bad connection from one of those wires to the switch, but more than likely it's the switch itself. You'll need to get a new one.
Old 03-06-2005, 08:37 PM
Basically's Avatar
Default Re: Need help with dash lights (litterbox)
Sweet thanks!!
Old 03-06-2005, 08:58 PM
NineTwoSi's Avatar
Dimmer switch or check out the headlight switch also... Mine is gettin' sketchy and I have to wiggle the headlight switch a little bit every once in a while.
cmwalker
01-17-2014 12:06 PM
Silvertune
11
04-15-2012 09:20 PM
italianchooch88
02-13-2008 01:45 PM
Jonathan_ED3
11
08-25-2005 03:47 PM
AMChev
10-14-2003 05:16 AM
Quick Reply: Need help with dash lights
