d15 general question
i recently got my hands on a jdm d15b vtech for my 94 cupe (dx)d15b7
before i drop the new motor in i want to change a few thing like all the seals gaskest and dissy but i dont know what toi get (dx,vx,ex,si) parts
i also heard you got to change the intake manifold is this tru
and one last thing what kind of timing elt should i get
thanks for all the help
Re: d15 general question (honda89ef)
A D15B Vetch is exactly the same as your D15B7 but with a Z6 head. A.K.A. Mini-me. Every thing is the same except for the head. If your still rockin a stock intake I would highly suggest (if you have the money) to swap it out for CAI or short ram. I recently installed a AEM short ram and now I wonder why I never did it sooner. It's a cheap upgrade that makes a noticable difference. Dizzy will have to be for a Z6 head and so will the timing belt. As far as the intake manifold goes, the head is different in size, but will still work with the Z6 head (all intake manifolds are interchangable). If you can pick up a Z6 intake manifold for cheap then by all means put it in (increases flow), but is not manditory.
Here is a good link https://honda-tech.com/zerothread?id=554053
good luck
Modified by Bond at 10:18 PM 3/8/2005
good luck
Re: d15 general question (Bond)
thanks for the answer i'll be doing the swap in a week or so those any one have a link or somthing for help what can i wile doing the swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">A D15B Vetch is exactly the same as your D15B7 but with a Z6 head. A.K.A. Mini-me. Every thing is the same except for the head. If your still rockin a stock intake I would highly suggest (if you have the money) to swap it out for CAI or short ram. I recently installed a AEM short ram and now I wonder why I never did it sooner. It's a cheap upgrade that makes a noticable difference. Dizzy will have to be for a Z6 head and so will the timing belt. As far as the intake manifold goes, the head is different in size, but will still work with the Z6 head (all intake manifolds are interchangable). If you can pick up a Z6 intake manifold for cheap then by all means put it in (increases flow), but is not manditory.
good luck
Modified by Bond at 10:18 PM 3/8/2005</TD></TR></TABLE>
your are very wrong here
the timing belt for a jdm d15b is a VX timing belt. THe valve cover is TBD but is most likely the Z6 cover. THe oil pan gasket i think is for a VX if i remember correctly.... it has been a few months. THe plugs are much colder than anything you can normally find, so if you are going turbo i would research find plugs for it first. Stock replacements are not difficult to find.
good luck
Re: d15 general question (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">
Considering that with a B7 block Z6 head (true mini-me), he would not be running a VX head; He will need a Z6 timing belt for a Z6 head. The VX timing belt has 103 teeth, Z6 104 and B7 belt 106. The VX timing belt will be to tight and cause it to whine. The Z6 is the right timing belt to use with a b7 block/Z6 head combination. If you don't believe me then check out this write-up and I have also done the mini-me conversion. If you have a B15B7 then what I have said above would be correct.
Modified by Bond at 11:21 PM 3/8/2005
HE HAS A D15B HE IS PUTTING IN HIS DX, WHICH ORIGINALLY IS A D15B7 EQUIPED VEHICLE. READ THE ORIGINAL POST!
he is not doing a mini-me. he is doing an entire swap. A JDM d15b takes a VX timing belt. If he were doing a mini me that would be a different story, but he is just doing a swap and wants to take care of the wearable stuff before he puts the engine in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">HE HAS A D15B HE IS PUTTING IN HIS DX, WHICH ORIGINALLY IS A D15B7 EQUIPED VEHICLE. READ THE ORIGINAL POST! </TD></TR></TABLE>
Good point! Maybe I will not reply to topics past 2 in the morning .
Vash121991
10-04-2013 10:00 AM
