00 si rear shock bushings?
do i not need to replace these when i install my new shocks? i looked on energy suspension's website and they only list a part number for the front bushings for a 99-00 si. any help is appreciated.
Re: 00 si rear shock bushings? (00civicsipa)
Which bushings are you talking about - the two bushings in the top hat assembly or the bushing in the LCA that the shock mounts to?
Part #16?
-OR-
Part #13?
Part #16?
-OR-
Part #13?
Re: 00 si rear shock bushings? (EE_Chris)
i was wondering if i had to replace either. i didn't see a lca bushing set for a 99-00 si either. i'm assuming the front top bushings will work for the rear top bushings?
Re: (pdiggitydogg)
yes i am talking about the top hat bushings. i also heard of alot of people breaking the bolt that holds the shock to the lca. i dont know if ill have that problem since my car is newer but if it does happen i will definetely have to replace the lca bushings, right?
Not necessarily.
My bolt broke and I was able to cut/drill/pound the thing out w/o replacing any bushing.
Sometimes, top hat bushings are included with new shocks (ie Koni). But generally, they dont need to be replaced anyway.
Re: (pdiggitydogg)
hey thanks thats good to know cause i heard the lca bushings were a pita to get out. i just bought my agx's and they didn't come with any bushings. if i were to buy the front shock bushing set from energy suspension would the top hat bushings work on the rear shocks?
Honda-Tech Platinum Member
OK back from the grave... I thought I would just revive this isntead of making a whole new thread... btw does prothane or ES sell the top hat bushings #16 individually?
Re: 00 si rear shock bushings? (aalb1)
i found a set in ebay http://cgi.ebay.com/ebaymotors...ZWD1V for a 99-00si em1. i have tein ss and based on tein's website my model (DSH98-KUSS2) are for Civic EM1/EJ6/7/8. so this set would work right?
Base on the pic above... #16 would be the ones on the side with the metal sleeve/collar... what are the 2 big ones in the middle?
SE7EN3S
03-29-2005 01:05 PM
RAB
11-23-2004 09:35 AM
