Engine Stalls
Engine Stalls
Wondering if anyone can help???? I have a 96 Ex with a B16 installed. Recently it has been stalling when I come to a stop? I added fuel injector cleaner and replaced my fuel filter, but it still cuts out. Anyone with this swap ever had the same problem?
Re: Engine Stalls (ttracing03)
check your injectors and your fuel pump and your throttle cable when you let off the gas it might close to much I had this problem before the nuts on the adjuster started to come loose and move.
i would do a tune up. like plug's wires the works being as u just swaped it recently. who knows when the last time anything was changed. sometimes stupid stuff causes little problems. check the pcv valve to. my buddies car did the same thing and after every time we started it and tested it and after fuel filter, PCV valve, and fuel filter it worked fine.
MI4$DC5
79
04-13-2010 11:13 AM
capm.stabahoe
12-27-2008 06:17 PM
dobbs1027
12-28-2004 03:17 PM
