Help: Putting a 97 GSR complete motor into 97' EK civic/ Need help for crank angle sensor at pulley
Help: Putting a 97 GSR complete motor into 97' EK civic/ Need help for crank angle sensor at pulley. I'm using the dx engine harness and the crank angle sensor at the crank pulley is a 2 pin connector on the 97' GSR motor. The 97' dx harness has a 3 pin plug. So i'm not sure what wires to use? can anyone help me out?
GSR
Civic 97' engine harness wiring colours CAS: blue w/ red stripe, brown w/ black stripe, white w/ red stripe
Acura integra 97' CAS wiring colours: blue, white
GSR
Re: Help: Putting a 97 GSR complete motor into 97' EK civic/ Need help for crank angle sensor at pul
hey im plannin on going b18c swap in my 97 civic. wat axles and engine mounts did u use? thanks
What ECU are you going to use? If you are converting to OBD1 then you wont need it i believe, I know you wont need it if it is a p28, not sure about p72.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhtHatchBack »</TD></TR><TR><TD CLASS="quote">hey im plannin on going b18c swap in my 97 civic. wat axles and engine mounts did u use? thanks</TD></TR></TABLE>
u just need b series axles, b series front tranny bracket and 99-00 Si rear engine bracket, also you need the drivers side bracket that mounts on the engine from an Si because the gsr one has 3 bolts for it to mount and the Si has 2 so it wont fit.
I just did the same swap into my 97 ek
gsr into ek using the dx engine harness.
What I did was chop the 2 pin plug off the harness that came with the motor and soldered it on to the DX harness. You just match the colors up and forget about the 3rd wire. It should run perfectly fine..
Remeber you have to extend those wires tooo...
97civic_ls
07-18-2008 04:45 PM
Wink1100
03-22-2005 05:43 AM
Wink1100
11
03-11-2005 01:14 AM
