si tranny
si tranny
let me 1st say that i did a search and didn't find anything.
anyways , i'm about the buy a si tranny out of a 95 civic but my question is how would i know for sure that it is a si tranny? is there a numer or letters i should look for? i need help quick i'm supposed to get it today.
thanks in advance
thanks in advance
Re: si tranny (nxstrikerxn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxstrikerxn »</TD></TR><TR><TD CLASS="quote">i recomend u go get the jdm d15b tranny or jdm d16a cuz their tranny have shorter gears n if ur lucky enuff u might get D series LSD </TD></TR></TABLE>
d15b trannys and ex/si trannys have identical gearing
thanks alot for ur help guys. well i got both of them is one better than the other? i think the s20 came out of a 94 cx and i dont know what the s40 came out of. i need to put a tranny in my car but i dont know which one i should put in
Re: (93blkej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">s40 for sure! its an ex tranny from 96-00 </TD></TR></TABLE>
Best d-series tranny there is... steel shifter forks.
Paper thin steel shift forks... I've been through 2 1-2 shift forks and two sets of bearings already. I've since gone back to a 94si tranny that I had laying around. Threw new bearings and seals in i t and its been going for 15,000mi already. Thats about double any of the ek trannies went.
Re: (viteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viteg »</TD></TR><TR><TD CLASS="quote">so i guess ex it is, will the dx axles from an auto work with the tranny?
Yah i also want to know if auto axles work with manual trannys
Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">Paper thin steel shift forks... I've been through 2 1-2 shift forks and two sets of bearings already. I've since gone back to a 94si tranny that I had laying around. Threw new bearings and seals in i t and its been going for 15,000mi already. Thats about double any of the ek trannies went.</TD></TR></TABLE>
Maybe you should learn how to shift correctly? It's no fun breaking a piece off your aluminum shifter fork when your street racing 100 miles from home. I will never run a tranny with aluminum shifter forks again.
http://www.homemadeturbo.com/f...00725
Re: (Morning Call)
i think the tranny in a 93 si would be a s40 also. the guy who i got mine from said it was from a 95 si.
Can some one tell me if the auto axles from my dx will fit in the manual si tranny?
Banned
Re: (fishnfst)
did you know you should use the clutch when shifting at 7000 rpm???
Risky Business
Re: (viteg)
Can some one tell me if the auto axles from my dx will fit in the manual si tranny?</TD></TR></TABLE>
Yes
Yes
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
I thought the passenger side was shorter?
Re: (shifty35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifty35 »</TD></TR><TR><TD CLASS="quote">
I thought the passenger side was shorter?</TD></TR></TABLE>
PLEASE tell me this isn't true.
Risky Business
Re: (viteg)
Uh, to my knowledge they are the same.
Go cross-check part #'s at http://www.slhondaparts.com to be sure.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Uh, to my knowledge they are the same.
Go cross-check part #'s at http://www.slhondaparts.com to be sure.</TD></TR></TABLE>
My bad... they are the same.
Re: (viteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viteg »</TD></TR><TR><TD CLASS="quote">i think the tranny in a 93 si would be a s40 also. the guy who i got mine from said it was from a 95 si.</TD></TR></TABLE>
92-95 EX/SI tranny's are s20 and they have aluminum shifter forks. The 96-00 EX tranny's are s40 and they have steel shifter forks.
