**stripted tension pulley bolt what tool to use to get bolt out***HELP PLZ**
ON my motor i need to loosen my timing belt but when i went to use the 14mm socket to loosen the belt the little brat stripped on me so now i can get the 14mm to grip it or a 14 wrench so my ? is isn there like a special socket i can buy to get the bolt out..
I have searched already and found no help there
you can get a bolt extractor but before you do that you might want to try using a 13mm socket or an SAE socket slightly smaller than 14mm and try banging that on top of the bolt... you don't wanna brake anything or ruin threads so be careful when you do that.... if that doesn't work get the bolt extractor
