b7 block y8 head...i need help fast
Risky Business
Re: b7 block y8 head...i need help fast (TurboEJ2)
I'm assuming this is in a 92-95 civic...
Theres one wire coming off of the solenoid, and two coming off the vtec oil pressure switch. Run the vtec solenoid to pin A4 on the ECU, and run one of the wires from the oil pressure switch to pin D6. The other wire from the oil pressure switch you ground out.
Read these
https://honda-tech.com/zerothread?id=1067906
https://honda-tech.com/zerothread?id=1019014
Read these
Re: b7 block y8 head...i need help fast (BauleyCivic)
yes its in a 94 civic...well i just got the solenoid, i didn't get it with the head and i don't have the plugs that plug into the solenoid.
like it came with tap #1 and #4 and #1 is like made into it. i don't have plugs #2 and #3. i can splice the wires on #1 if i had to but i can't with #4 what do i do with it?
________
Republica
________
Republica
Risky Business
#1 is the VTEC solenoid wire...you can cut it before it gets to plug #1 and just run it straight to the ECU if you want.
#2 is the oil pressure switch, a $48 part if you buy it new from honda. Try and find a junkyard and see if you can get one from a civic there. Its a 21mm or 22mm socket I can't remember. You can see there are two wires coming off plug #2, #4 is just the ground wire for it.
thanks for clearin up the #1 problem. but the other problem is that i have #4 which is the one that is tapped into the solenoid. i don't have #1 that plugs into it that has the 2 wires comming out of it.
________
YAMAHA XV250
________
YAMAHA XV250
thats #4 and #2 is the thing that plug into it. i don't have #2 that plugs into that. i guess the female tap i dunno.
Modified by TurboEJ2 at 11:03 AM 11/25/2005
________
Friend advice forums
u thought i ment #4 was the ground wire. no i ment it was the plug on the solenoid
________
Stocks To Buy Now
________
Stocks To Buy Now
Risky Business
okay, if you have #4 thats good...just go to a junkyard and grab a plug that looks like it will fit, there are several on hondas that do...i got a yellow one
think u could get me one and i pay you for it? there are no junkyards close to me. and i don't want to drive an hour to get a plug from a junk yard
________
Swiss cooking
________
Swiss cooking
oh one more thing. would it be safe to run the combo with out the solenoid hooked up? well atleast until i get the plugs? cuz this is my daily driver lol
________
Wellbutrin Injury Lawyer
________
if i take the oil pressure sensor/switch and put audio clips on the two nipples inside the sensor/switch and run wire to them will it work? and just ground one and run the other? like this...
^i couldn't find any pics so i made one but you see what i mean? if i took the clip and put a wire in it and hooked it to the nipples in the sensor...would i work if i electric taped it so it wouldn't fall off? just for time being...
________
Full melt hash
________
Full melt hash
JSPECSIR
10-07-2008 06:56 PM
iphatcrxi
03-07-2005 09:52 PM
TheHatchHog
05-01-2003 03:30 PM
