Headlight Question
Mr. Indecisive
Headlight Question
Sounds stupid but does anyone know if u can make the lowbeams stay on when u put the highbeams on?? Its a 2000 civic.
Thanks
Thanks
Re: (JDMlyfestyle)
if you hold the switch back instead of releasing it then they all stay on, im sure you could figure a way to make em both on.
i can see everything with high/low/fogs on at same time, but i cant sit there and hold it, thats not smart driving
Re: (93egsedan)
Ok this is how you do it. Take the wire from the low beam. Cut it 3-4 inches after the socket.
then connect the wire to end of that and run it to the foglight spot in your fuse box.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Ok this is how you do it. Take the wire from the low beam. Cut it 3-4 inches after the socket.
then connect the wire to end of that and run it to the foglight spot in your fuse box.</TD></TR></TABLE>
Not to be a dick, but could please rewrite this using a little better grammar?
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">NOt to be a dick but that seems pretty damn simple to me. Figure it out!</TD></TR></TABLE>
Don't get all defensive. It doesn't make sense.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Ok this is how you do it. Take the wire from the low beam. Cut it 3-4 inches after the socket.</TD></TR></TABLE>
Check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">then connect the wire to end of that</TD></TR></TABLE>
Connect what what wire to the end of what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">and run it to the foglight spot in your fuse box.</TD></TR></TABLE>
I would if I could figure out what wires you're talking about.
Check
Take a wire and connect it to the End of the Low beam wire coming off the socket... this is the wire that you cut!
Then run that wire into your interior and connect it to the Lighting spot on your fuse box..
Understand it better?
No offense but i rarely see people putting effort into things and always want to be told out right how to do it.
Like people are IMing me asking me how to install a S2000 gauge cluster into a EG and they expect me to tell them outright.. Ive spent over a 100 hours trying to figure it out and i havent even finished it and people expect me to tell them.. haha sorry not that easy
Imperious: Mod of Valor
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">No offense but i rarely see people putting effort into things and always want to be told out right how to do it.
Like people are IMing me asking me how to install a S2000 gauge cluster into a EG and they expect me to tell them outright.. Ive spent over a 100 hours trying to figure it out and i havent even finished it and people expect me to tell them.. haha sorry not that easy</TD></TR></TABLE>
Do a write-up? I think this would solve 99% of those PMs you get.
I wont do a write up. Cause id like to have something that makes me different than all the other EG's out there..
Like my IS300 Retrofit. ill never reveal the mounts for that. I like to be Unique which is very hard to do with our cars.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">I wont do a write up. Cause id like to have something that makes me different than all the other EG's out there..
Like my IS300 Retrofit. ill never reveal the mounts for that. I like to be Unique which is very hard to do with our cars.</TD></TR></TABLE>
Well, then you need to stop complaining about getting PMs about it then. You can either: Stop whining about getting PMs about things you do to your car. Or, you can post up write ups so others can learn.
Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Well, then you need to stop complaining about getting PMs about it then. You can either: Stop whining about getting PMs about things you do to your car. Or, you can post up write ups so others can learn.</TD></TR></TABLE>
DUde, who are you to tell him? JDMlyfestyle has already done a bunch of helpful writeups. If i were him, i wouldn't tell people how to do stuff like the IS300 foglights retrofit either. It is very hard to be unique, and it must be very satisfying knowing that you have something on your car that no one else does.
Re: (TopSecretEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopSecretEg6 »</TD></TR><TR><TD CLASS="quote">
DUde, who are you to tell him? JDMlyfestyle has already done a bunch of helpful writeups. ]</TD></TR></TABLE>
True that JDMlyfestyle has ALOT of helpful writeups, its good to have people like him on this forum.
Mr. Indecisive
Re: (BiRdMaN121486)
Ok now let me ask u this, if i do wire it into the foglight spot on the fuse box, what happends when i install my fog lights??
Modified by EJ8VTEC at 2:29 AM 11/26/2005
Re: (TopSecretEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopSecretEg6 »</TD></TR><TR><TD CLASS="quote">DUde, who are you to tell him? JDMlyfestyle has already done a bunch of helpful writeups. If i were him, i wouldn't tell people how to do stuff like the IS300 foglights retrofit either. It is very hard to be unique, and it must be very satisfying knowing that you have something on your car that no one else does. </TD></TR></TABLE>
That's true. He has done a bunch of helpful write ups, I wasn't talking about those. He specifically used the example of the s2k cluster in his and about people PMing him about those, that's what I was referring too.
mgabe
Honda Civic (2001 - 2005)
11-11-2016 04:48 PM
eghatchin
16
04-25-2008 04:46 PM
