how to: jdm vti-rs climate control ?
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
i have a ek jdm vti- rs climate control? how am i gonna make this work?
my stock usdm climate switch are on a cable? this jdm one is like the 99-00 si one?
Location: Where the shooting range is on the streets of LA, CA.
Re: how to: jdm vti-rs climate control ? (honduhh)
you cant unless u change your whole a/c system to the 99-00 si a/c system.. its all motorized.. thats what u need.. unless u dont have a/c and u want it for looks... then just bolt it in... i seen that climate control, that **** is rare... i wanted to get it also but then i had the same problem u have... good luck...
Re: how to: jdm vti-rs climate control ? (mugen mj5)
i dont have AC. but i have heat..how will i get the dial to work for the heat since its on a cable in my usdm car
the rest will be all plug and play?
u cant use the heat/cold dial to control your heat from the RS climate control ... remember the dial is a switch to open and close and control how much air flow u want from hot or cold on the air vents from the 99-00 civics.. the 96-98 civics vents is maually opened or closed by a cable.... so if u dont have a/c but still want heat coming in your car, leave the cable open for heat and just remove it from the car or hide it.. and if ur asking about the rest being plug and play, experiment with it... see what plugs fit in to what... i know for sure that either the defroster or emergency plugs need to be modified... its one of those i forgot which switch was it.. this is for the jdm 96-98 climate control ctr,sir,vi-rs, etc... i have a 97 ek and i slapped on a 96-98 ctr climate control but i had to modify only ONE of those switchs... (defrost button/ emergency button) the other one is plug and play... but good luck man hope everything works out for your car bro...
you should just sell that to me since i got the 00 hot shiiittt.
research before you buy yoo
BLINGBLINGKRN
11-16-2004 05:58 PM
