Exhaust rub is driving me insane.
Ladies and gentlemen we are floating in space...
(I did a quick search but didn't find anything on the topic)
My exhaust piping is rubbing underneath my car and it's driving me insane! The noise gets worse with added passengers...my friend's DC2 had similar problems, and my old exhaust did the same thing. Is there a quick, known fix for the problem? I'm assuming this happens in most Civics and Integras given that I've seens 3 exhaust (Apexi, Tanabe, Mugen) doing the same thing on 2 different car.
Any ideas are greatly appreciated
Re: Exhaust rub is driving me insane. (Regal)
What do you mean by rubbing? Vibration? or what? How do you know its your exhaust? Have you inspected your exhaust to see if its hitting anything? (ex: heatshields underneath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Regal »</TD></TR><TR><TD CLASS="quote">(I did a quick search but didn't find anything on the topic)
Any ideas are greatly appreciated </TD></TR></TABLE>
Its probably rubbing on ur gas tank if its a apexi N1..
Re: Exhaust rub is driving me insane. (Ls_TurboEG)
the n1 on a coupe doesnt even come near the tank, nor does it on hatchs, it drops below the lca but not under the tank
Re: Exhaust rub is driving me insane. (tuck'd98)
no, the apexi n1 does hit my gas tank but is dosent do it any more, I just bent the stock hanger a little its good now, and the exhaust does go over the lca and hit the SIDE of the tank
I'm sure it's the exhaust rubbing; I guess my question is: what kind of material could i use to coat/pad/wrap the area where the pipe is making contact with the car?
Is there some sort of melt-proof rubber I can buy somewhere?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 »</TD></TR><TR><TD CLASS="quote">wow ive had 2 n1's one on the old hatch, no probs, nd on on my coupe now and no probs</TD></TR></TABLE>
obviously u havent seen the new ones if they're still goin under the lca...
HT Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Regal »</TD></TR><TR><TD CLASS="quote">I'm sure it's the exhaust rubbing; I guess my question is: what kind of material could i use to coat/pad/wrap the area where the pipe is making contact with the car?
Is there some sort of melt-proof rubber I can buy somewhere?</TD></TR></TABLE>
See if you can find exactly where its rubbing. I had that problem with my WS on my coupe... the problem was the axle-back flange was actually hitting and rubbing on the brake line. It wore through the line. I had to buy an entire new rear pass brake line.
mine hits on my heatsheild on 4deg it vibrates for like the 1st 3 minutes before warming up
also a n1 with big piping, is it safe to remove this heat sheild?
i was thinking about wraping the pipe where it hits in heat wrap to it wont be metal to metal and be more silent
johnRsX05
01-04-2005 07:13 PM
