lsvtec set up.... help... opinions wellcome
Well i have a 2000 SI and after been racing with the same cars over and over again i realized that it's time for me to step up... i'am thinking about doing a lsvtec so... my setup might be this.
I search on Eagle for the lsvtec conversion kit that they got.. is it good?
ARP head studs, ARP rod bolts ... HELP OPINION
B18LS block honed, bored 81.5mm
CTR oversize 81.5 pistons HELP,OPINION
Rods... are the ls rods too bad? or can i use my B16 ones?. or which one should i buy? HELP,OPINION
Type r oil pump
Walbro 255 fuel pump
UR crank pulley
UR Alt pulley
YES i will keep AC, PS
what head gasket should i use? HELP OPINION
Do i really need a block guard? HELP OPINION
B16 head
Jun stage 2 cams
Jun valve springs
Omni power retainers
JDM 4-1 header ( they are not good but for now they will )
Omni test pipe
Apex N1 full exhaust 2 1/2
skunk2 intake manifold
bored b16 throtle body ( maybe 62mm ) HELP,OPINION
STR cam gears ( tune right with the right people )
Aem fuel P.R
Aem fuel rail
injectors ( thinking about jdm h22 that my friend is not using ) HELP,OPINION
cold air intake
B16 tranny
Exedy stage 1 clutch
Exedy 9.5 lbs flywheel
CTR or ITR lsd ( need help on what i need to install lsd on a B16 tranny ) HELP
P28 ecu
Skunk 2 jumper harness
Hondata s100 tune the right way with the right people
thanks god we good 93 octane in FL
the build up would be done with all new parts, new seals, gaskets, etc etc etc....
REMENBER that i'am not thinking on a monster build up... it's just something reliable and good for a daily driver..
PLEASE help on anything you see kind of weird... thanks a trully NA lover
Type r oil pump
UR crank pulley
UR Alt pulley
B16 head
Jun stage 2 cams
Jun valve springs
Omni test pipe
Aem fuel P.R
Aem fuel rail
cold air intake
B16 tranny
P28 ecu
Re: lsvtec set up.... help... opinions wellcome (NAlover)
B18a or B18b .... not B18LS
Golden Eagle makes an excellent kit.
Use the standard bore unless the sleeves are scarred.
Rods are fine. If you want some extra strength have them shot-peened. They will need to be machined to accept the B16 wrist pin.
Rod bolts are the weak link...upgrade with ARP.
Type-R oil pump is the same as any other VTEC oil pump.
Use Tri-metal bearings, VTEC Water Pump, and B18 Timing Belt.
Use the OEM pulleys.
Use the B16 Head Gasket (golden eagle kit will come with this)
No, you don't need a block guard.
I believe the H22 injectors will need a resistor box.
OEM Fuel rail and regulator should be fine.
so just put CTR pistons stock bore...
can i use my B16 water and oil pump???
i already have the UR pulleys the AEM stuff that my friend gave me because he did't have money to pay me what he owned me... so that gotta go with the buid up.
what would be the compression with the CTR pistons with fully built Jun stage 2 B16 head??? i don't wanna be too high on compression
The B16 oil pump/water pump will work perfectly.
I'd recommend the B16 (PR3) pistons for ~11.6"1 compression and the Skunk2 Stage2 Cams.
With a Hondata and a good tune, you should be closing the gap on 200whp.
i talked today to the shop where the car will be built and they got 4 coupes with almos the same set up and they have 1 year 2 years running good no smoking nothing....
B18b/a block stock bore
12.5-1 pistons Arias,Wiseco etc etc
Eagle rods
b18 main bearings
b18 rod bearings
block guard
Golden Eagle ls/vtec kit
ARP head studs
UR crank pulley
UR alt pulley
Toda spec A cams
Type R dual valve springs
Type R retainer
Type r valves
STR cam gears
Bore b16 throtle body
Aem fuel P.R.
Aem fuel rail
cold air intake
JDM 4-1 headers
Omni test pipe
Apex N1 exhaust 2 1/2
Walbro fuel pump
B16 tranny
exedy stage 1 clutch
exedy 9.5 lbs flywheel
itr - ctr lsd
p28
Hondata S100
93 octane tune right with the right people.
what you think?????
later on 125 shot of Tropicana JUICE
Eagle rods
b18 main bearings
b18 rod bearings
block guard
ARP head studs
UR crank pulley
UR alt pulley
Toda spec A cams
Type R retainer
Type r valves
STR cam gears
Aem fuel P.R.
Aem fuel rail
cold air intake
JDM 4-1 headers
Omni test pipe
Walbro fuel pump
B16 tranny
itr - ctr lsd
p28
Hondata S100
what you think?????
If you're having a shop build it, and they already have a preference, just go with it. Let them build it the way they like, and with what's worked for them.
With CTR pistons your compression will be extremely high for pump gas, i believe ~12.4:1, but dont quote me, personally i wouldnt use for a daily driver. 12.5:1 compression and up has to be ran on race fuel also. Good luck!
Re: (JDMracer17)
I know what you are saying and its true. BUT we have 93 octane gas in FL and i dont use my car too much i live 5 minutes from work. BUT yeah 12.5-1 is high i know that too but the shop has built 4 engines with the same sep up, and those cars are daily driver. they told me good tunning HONDATA, 93 octane you will be fine... BUT i don't really know what to do ...
NAlover
38
09-15-2006 02:01 PM
