DAY 2: Swap is about 60%
Well I kept at it determined to put the engine in alone and
save myself some money. Axle nut problem has been fixed
due to assistance with a grinder. I just cut the bolt and will replace.
Here is what it looks like now...
All I have left is:
put the suspension back together
Put the axles in
put the engine harness on
attach shift linkage
re-do (1) lower ball joint
install P75 ECU
I think thats about it and one last thing "pray it starts"
If anyone has any tips or things i should look out for let me know...
Thanks H-T for all your help!!!!!!!!!!!
All I have left is:
Put the axles in
install P75 ECU
I am a (Trial User) Army
Re: DAY 2: Swap is about 60% (fasterthenmost)
You forgot you need to re-attach the exhaust.
What's that blue wire that runs along the firewall? Looks good so far now man.
Guest
Posts: n/a
Re: DAY 2: Swap is about 60% (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">You forgot you need to re-attach the exhaust.
What's that blue wire that runs along the firewall? Looks good so far now man.</TD></TR></TABLE>
looks like amp wire..
Re: DAY 2: Swap is about 60% (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">
looks like amp wire..</TD></TR></TABLE>I wanted him to answer so I could make fun of him (in a nice way)
Re: (litterbox)
I have one suggestion next time out the harness on before you put the motor in! You can make it a little cleaner and you can get every angle with out much trouble! That's how I do it anyways! for doing it yourself!
Dutch
Dutch
Guest
Posts: n/a
Re: (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT »</TD></TR><TR><TD CLASS="quote">I have one suggestion next time out the harness on before you put the motor in! You can make it a little cleaner and you can get every angle with out much trouble! That's how I do it anyways! for doing it yourself!
Dutch</TD></TR></TABLE>
definetly (harness)
definetly (harness)
Re: (ThefirstPACT)
I second that
I second that
civic92vx
06-29-2010 09:55 AM
tek_civic
05-14-2006 02:04 PM
MonkeyPuzzle
08-16-2005 09:26 AM
