y8 manifold on b7
y8 manifold on b7
Has anyone ever put a y8 manifold on a b7? I tried doing this but it didn't bolt up and the fuel pressure regulator is on the opposite side as well as a different type. Any advice? Thanks.
Re: (skelly ed666)
the fpr is a different design on the y8. The manifold is a 99-00 one. The holes line up, but the block gets in the way because the manifold needs to be grinded down.
Re: (Stevorh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stevorh »</TD></TR><TR><TD CLASS="quote">The holes line up, but the block gets in the way because the manifold needs to be grinded down.</TD></TR></TABLE>
What?
This manifold does fit your block.
What?
Re: (fast88std)
(STEVORH) Its not a direct bolt on. You will have to trim the top of the manifold flange to clear the head. Or you can grind the head a little. Just use the y8 fuel rail with your old injectors and it will solve you fpr problem. The only other thing i had to do was drill the holes for the iac valve on the back of the manifold. Kinda tricky, but it works.
Guest
Posts: n/a
Re: (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 »</TD></TR><TR><TD CLASS="quote">(STEVORH) Its not a direct bolt on. You will have to trim the top of the manifold flange to clear the head. Or you can grind the head a little. Just use the y8 fuel rail with your old injectors and it will solve you fpr problem. The only other thing i had to do was drill the holes for the iac valve on the back of the manifold. Kinda tricky, but it works.</TD></TR></TABLE>
the 96-98 you dont have to do that.
Re: y8 manifold on b7 (Stevorh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stevorh »</TD></TR><TR><TD CLASS="quote">Has anyone ever put a y8 manifold on a b7? I tried doing this but it didn't bolt up and the fuel pressure regulator is on the opposite side as well as a different type. Any advice? Thanks.</TD></TR></TABLE>
What is a B7?
What is a B7?
Re: y8 manifold on b7 (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S »</TD></TR><TR><TD CLASS="quote">
What is a B7?</TD></TR></TABLE>
D15B7 from 92-95 DX, LX
Re: y8 manifold on b7 (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
D15B7 from 92-95 DX, LX</TD></TR></TABLE>
Gotcha... I was thinking he ment a Y7 and was wondering how the hell he was having problems
GiMpInThaCiv
10-31-2006 01:58 PM
Irishweird00
03-27-2003 08:45 AM
fastcrxsi90
12-24-2002 03:51 PM
fastcrxsi90
12-24-2002 10:03 AM
