Door indicator light wiring diagram?
i installed the eg9 cluster forever ago and i knew when i put it in my car the door indicator wouldn't be prewired for it as for the low fuel light and it was no big deal. the gas i can live without but i would like the door indicator to work, it is one of those things that never will get used but i would like for it to work. there is a green plug that has like 8 prongs directly behind it so i think that is what it goes to but i couldn't find a plug back there to fit it. does anyone know where i could find someone that would know what went to what?
this is what cluster it is if anyone wants to see it. it is the door indicator under the tach.
1 Post
if you want this to work you will have to some work yourself. first, get a meter out and determine which pins go to which indicator for the doors, and which ones are common and for illumination. then start at 5v and test if the door thingy is 5 volt or 12volt. once you figured out the pinout, then solder leads from the pins and heatshrink them at the end so none of them will short.
next, go to each door pin and install a diode so the pin is isolated from the rest of the dome light circuit.
connect your isolated door trigger to each of the dash indicator lights...
voila.you have a jayed out door indicator.
Re: (yaoming315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaoming315 »</TD></TR><TR><TD CLASS="quote">anybody know where the door/switch wire is on a 92-95 civic? is it a black/white or green/red wire? thanks</TD></TR></TABLE>
Whatever color is coming from the door sensor. I don't remember what color it was when I wired up my lights.
Re: (yaoming315)
also, for the srs wire on a 92-95 civic, is it the blue wire on the 3 wire connector or is it the yellow wire. I'm trying to figure out which wire i need to connect to my s2000 cluster to get my srs light. somebody told me to connect the blue wire to the s2000 cluster. can you confirm that for me? but what about the other 2 wires? thanks
Re: (yaoming315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaoming315 »</TD></TR><TR><TD CLASS="quote">if you have time, can you take a quick picture of the plug where the wire is? It would help me a lot. thanks</TD></TR></TABLE>
You know that black sensor below the B-pillar? You push the sensor and the interior light turns off? Yup, that is your sensor. You'll need to pull out the panel to get access to the wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaoming315 »</TD></TR><TR><TD CLASS="quote">also, for the srs wire on a 92-95 civic, is it the blue wire on the 3 wire connector or is it the yellow wire. I'm trying to figure out which wire i need to connect to my s2000 cluster to get my srs light. somebody told me to connect the blue wire to the s2000 cluster. can you confirm that for me? but what about the other 2 wires? thanks</TD></TR></TABLE>
I believe it's blue because Honda often uses yellow wires as "hot" wires. Black is ground.
