popping noise
popping noise
ok i did a search and came up with nothing. my car has been popping lately on bumps, and slight turns. i got the car in the air and checked everything. cv axles boots have no tears and do not click, but the outer tie rod bushing is broken with no grease inside. would this be my problem and if so does anyone have a write up on it? i also have hassport mounts also if that is any help(stiffness) thanks
Re: popping noise (sheBangZ)
when you look at your sway bar, the big black thing running LCA to LCA kinda looks like
_ _
\__________/
you will see things that connect from the hole in that to the LCA, check those
also yes the tie rod end could be causing the popping noise
_ _
\__________/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ »</TD></TR><TR><TD CLASS="quote">cool, thanks, wut level difficulty is it?</TD></TR></TABLE>
i think the words easy as **** come to mind hahaha
when you do the tie rod end though, be careful and try not to spin the tie rod itself, and count how many turns it takes to get the end off, then when you put the new one on, turn it on that many times, and tighten the jam nut. then take it in for an alingment
HondaLuv3r4Life
Honda Civic (2006 - 2015)
11-01-2016 09:44 AM
Dunks
12
01-06-2014 08:42 AM
EM1 Loi
07-31-2008 09:15 AM
