Brake conversion need help!!
I have a 2000 civic ex (2door) i just bought from a 2000 civic si the rear discs with arms. Does anybody know what else im going to need to make this work? i was told i need to change the E-Brake cables. Also i been hearing i might need the master cylinder and the proportion valve? any help would be great thanx!!!
Re: Brake conversion need help!! (xtreme412)
Well since your car didn't come with rear disc brakes, you will need to use the Si e-brake cables. You don't need to replace the prop valve or MC/BB if you don't want to. I upgraded to the Si MC/BB since it was a little bigger than the stock DX one.
Your 00 EX Coupe non ABS already has the same BMC and BB as the EM1. Some people swap the Prop Valve, which is what I recommend. Some don't.
Like ^^^, snag those Ebrake cables!!
Do you have ABS?
JasonGhostz
Do you have ABS?
JasonGhostz
Re: Brake conversion need help!! (xhatchracerx)
you will need the following
Rear brake assemblies
E-brake cables
rear brake lines
you do not have to upgrade MC/BB if ytou do not want to, you will have about the same braking performance as before if not a little better due to increased diameter.
The proportioning valve does NOT need to be replaced and I will continue to stand firm on this one.
E-brake cables
rear brake lines
Re: (DirtySol)
ok well the master cylinder and the brake booster is the same part number the prop. valve i cant seem to find info on that so im gunna have to call the dealer monday. the cables though im def. gunna need. besides the motor,tranny,seats,red si cluster lights and rear brakes r theyre any other differences in my 2000 ex??
Re: (xtreme412)
I don't know if you "need" it or not, but the EM1 has a different "Master Power Tube Assembly" (Chassis/Master Power (brake hydraulics)). The EM1 shows as PN 46402-A02-A11, while the 2000 EX Coupe non ABS shows 46402-A01-A11. Also, the prop valve is 46210-S04-902 for the EM1, and 46210-S04-962 for the 99-00 EX. Whether you "need" it or not is debatable, but I'm on the "paranoid" side that says why not go for the swap.
The Rear Stabilizer Bar, Links, Mounts, and Mount Bushings are missing from your EX. Sideskirts, Front & Rear Lower Lips, and emblems are also missing. (edit: oops, I mean the sideskirts are painted)
There are bound to be more... you can find it out there.
JasonGhostz
JasonGhostz
Re: (JasonGhostz)
what stabalizer bar? its showing me at http://www.hondaautomotiveparts.com thats theres only one in the front?
Re: Brake conversion need help!! (MackEg6)
You're going to want a can or two of PB blaster! Soak those bolts before you try and remove them!
And be sure to load your suspension before you go after those compensator arm bolts.
Might as well do the stainless lines while you're at it! Replace the TA bushing because it's probably torn somewhere...
I did everything I could think of while I did my swap... I am ******* sick of taking **** apart twice
Re: Brake conversion need help!! (shelby5k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shelby5k »</TD></TR><TR><TD CLASS="quote">does all of this rear disc conversion also apply to a 98 civic hatchback dx</TD></TR></TABLE>
An ek hatch has the same prop valve as a si,
so you dont have to change that
RotaryPWR
11
08-10-2009 05:42 AM
2DoorBandit
12
07-07-2006 12:14 PM
fathergoose
08-24-2004 10:41 AM
