TPS code problems
Old Nov 24, 2005 | 10:26 AM
Hatchd's Avatar
Default TPS code problems
First off, yes ive searched but havent gotten an answer that works.
Ok, 93 hatch running a jdm gsr motor, ITR IM, and a p28 ecu. Had to replace the tps sensor cuz the one on the motor was broke. Replaced it with a known good one and threw a code 7. I knew it was off so i got a voltmeter and adjusted it today. Set it to .45 at idle and 4.55 at wot. I then turned the car off, unhooked the battery for 15 minutes, started the car and let it idle for about 15 minutes, turned it off, turned it back on, and the code is still there. Took it out for a drive and it idles fine, runs fine, pulls hard, etc. Just still have the code. All the wiring is correct because the harness worked fine on the motor that I pulled out and I didnt have to run any extra wires for this motor other than a knock sensor.
Anyone have any idea how to clear this code off? Or is there something I'm doing wrong? I've checked everything that all the posts I searched recommended and still got nothing. TIA for any help.
Old Nov 25, 2005 | 03:24 PM
Hatchd's Avatar
Default Re: TPS code problems (JapTendencies)
anyone?
Old Nov 25, 2005 | 04:27 PM
postman's Avatar
disc battery pull ecu backup fuse , also just pull the ecu
Old Nov 25, 2005 | 04:30 PM
95DxSi-R2
Guest
Posts: n/a
what is code 7?
Old Nov 27, 2005 | 08:58 AM
Hatchd's Avatar
Default Re: TPS code problems (95DxSi-R2)
code 7 is a tps sensor code.
And Ive gotta work on the car again today so I guess I'll just unplug everything and see if that works.
Old Dec 1, 2005 | 07:17 PM
akteamster's Avatar
i have a code 7 also in my car......96 ek with a jdm b18c also.
will this code prevent vtec from kicking in?
Old Dec 2, 2005 | 05:31 PM
Hatchd's Avatar
Default Re: TPS code problems (akteamster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster &raquo;</TD></TR><TR><TD CLASS="quote">i have a code 7 also in my car......96 ek with a jdm b18c also.
will this code prevent vtec from kicking in?</TD></TR></TABLE>
It shouldnt prevent vtec from kicking in. On my car it was way off(.01 at idle, 3.24 at wot) and when i hit vtec the car would sputter instead of actually hitting vtec. If your car does that then thats normal if its way off. The ecu doesnt know wtf to do or how much gas to give the car so it basically sends it into limp mode(someone correct me if I'm wrong, this is just what ive found).
Still, anyone out there no how to get rid of this? Ive tested it now, a week later, and its still reading .44 and 4.55 at wot. The car idles a little rough, almost like it has a cam(real lopey). Could this be because of the tps? Should I adjust it higher to see if the idle will correct itself? Or possibly run it lower to smooth it out? I'm lost, any help would be appreciated.
Old Dec 3, 2005 | 11:34 AM
akteamster's Avatar
bump for some more answerssss
shabam
Oct 23, 2006 07:14 AM
NitrousB.I.G.
Mar 26, 2005 09:22 PM
smokinsi
Jul 18, 2004 05:09 PM
