toe in alighnment question
I have a 2 finger gap between tire and fender in the front. I just got this car and have no idea how much it is lowered but it is wearing the inside of the tires. Before I go and waste money on getting it alighned, does anyone know if there is enough adjustment left to make it stop wearing?
I don't have adjustable camber kit, all stock except springs
Re: toe in alighnment question (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">just adjust your toe and your good. no need really for an alignment</TD></TR></TABLE>
An alignment is what adjusts the toe. It's the only alignment setting that can be changed on a civic without a camber kit. And if you want to 'just adjust your toe' you'll need these at a minimum:
http://www.longacreracing.com/...tid=5
And to do a proper 4 wheel alignment (which is what he needs) it's a bit more intensive; in order to eliminate thrust angle. You will have to 'string' the car:
https://honda-tech.com/zerothread?id=597192
Just take it to a shop and have them set the toe to 0 and you'll be fine.
Re: (sbcs15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sbcs15 »</TD></TR><TR><TD CLASS="quote">so I still have room for adjustment, its not maxed out yet?</TD></TR></TABLE>
Yes, go and get an alignment. Make sure you get before and after printouts, and get the toe set as close to 0 as possible.
