transmission problem
93 civic si d16z6
i ran into a road block ......... ok something with the tranny, or the fork, when bleeding the clutch the piston on the slave cylinder is extended all of the way causing a fluid leak so i got a new cylinder .... same problem ....arg.... so it looks like i need to drop the tranny and see if the fork is in right and check out the throw out bearing
Drizzo
13
08-05-2004 08:44 AM
civic_speed99
13
07-16-2004 08:19 AM
