SOHC motor tear down, need advice, suggestions before I do it!
Yes, I have decided to replace my rings due to them being blown...
Motor 1.5L SOHC D15B7 Non vtec
Going to rip my motor apart this weekend,
Just need your helpful thoughts and advice in case I foregot something...
I bought new rings, rod bearings, motor oil, coolant, Head gasket (D16y8 metal/thin)
I am going to replace them while the motor is still in the car,
I am going to- Take off head
take off oil pan
windage tray
2 rod bolts
push piston out though Top of block
Now, when ALL pistons are out of the block I am going to HONE the Cylinders, make some nice cross hatches.
Hone W/ Brake parts cleaner, and clean the hell out the cylinder making sure no metal shavings are left in.
Now I put rings on pistons w/ring compressor tool ( suppos ill have to borrow one from autozone.
replace bearings, put engine assembly lube on them.
And install reverse of removal.
any thing I left out?
I was also told to do the "break in" part of the motor after I get here running, I guess thats like a cluch break in? Dont shift past what 5k? for 500 miles?
Anything else I should be aware of?
Tank YOU!
take off oil pan
windage tray
2 rod bolts
Tank YOU!
Re: SOHC motor tear down, need advice, suggestions before I do it! (zx2gotboost)
dont forget to gap the rings
my friend got a snap on ring compressor for $12 brand new
ebay has them cheap too
Re: SOHC motor tear down, need advice, suggestions before I do it! (komat)
ok,
thank you!
Guess ill look up specs now, im sure itll be in my repair manual?
Do I need a "feeler gauge"?
thank you!
O, I forgot, guess ill need some sillicone for the pan reseal huh ?
Re: (zx2gotboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx2gotboost »</TD></TR><TR><TD CLASS="quote">other than that, everything else look good?
I may replace the plugs as well..
Where might I get "hondabond" ? </TD></TR></TABLE>
honda dealer its like $10-15 for a tube of it
just go to an auto part store, get some ATV gasket for $3
i would also recommend buying a ring filer to file down the rings to the correct size
all the required tools and torque specs are listed in the repair manual. When you hone the cylinders make sure you clean the cylinders and crank very thoroughly. All the small metal particles from honing can stick to the crank and cause major problems to your new bearings.
Re: (komat)
****..... there not just O slap in operation typoe deal? Figured all I have to do is "gap" them tp specs, and thats it........ DAMNIT...
Cap'N Chronic
11-16-2012 10:40 AM
ohsnapzafingcu
13
04-10-2011 06:52 PM
JDMister_EF9
01-17-2007 09:54 PM
tempsohc
05-24-2006 08:11 PM
zx2gotboost
12
02-01-2006 10:21 AM
