engine build
Old 01-12-2006, 06:37 PM
speedncivic's Avatar
Default engine build
Would it be better to have the B18c1 block bored to 2.0L and sleeve it or would it be better to bore it to 84mm and sleeve it both using JE 9.0-9.5 : 1 pistons and Eagle rods. Keep in mind I want the compression to stay down for a turbo build. Also that motor is Vtec right. I mean this build would be considered a built GSR turbo build right.
Old 01-12-2006, 07:00 PM
redlshatch's Avatar
Default Re: engine build (speedncivic)
you might want to figure out what you're building before you build a motor.
Old 01-12-2006, 07:04 PM
I do know what I am building but I just wanted to throw around some different ideas to see what others thought. Thanks for not helping much.
Old 01-12-2006, 07:07 PM
redlshatch's Avatar
Default Re: (speedncivic)
my bad man.....well is it going to be a daily driver or a track car? How much whp are you shooting for? If its going to be a track car go for the 2.0 if its going to be a daily driver i would just suggest going with the overbore.
Old 01-13-2006, 02:41 PM
Default Re: (redlshatch)
Its cool. It wont be a daily driver, more like a weekend thing and shows. Stuff like that. But I want to do some track runs. I am shooting for 400+ whp. I read an article a few months ago and someone took this motor and got 540+ but they didnt say anything more than what type of motor and turbo settup they were running. That would be the ultimate goal but I am trying to be realistic and relatively safe but Iat the same time I want to be able to smoke some asses. You know what I mean?
Old 01-13-2006, 03:13 PM
just Touge's Avatar
If you want turbo build an LS or B20.
Old 01-14-2006, 08:13 PM
redlshatch's Avatar
Well if you sleeved the block you would def. be able to with-hold 400whp....providing you do everything else right as well. Just sleeving the block doesnt mean you can just push everything else in the motor to 400hp......know what i mean? It wont be cheap either though so plan on spending alot of money.
Frost7177
07-31-2011 10:17 AM
thatwhiteguy
01-22-2007 10:33 AM
Big Phat R
12-19-2006 03:33 PM
nomad_G3 Turbo
11-03-2004 06:11 AM
Quick Reply: engine build
