gsr P/S pump on Ek
Re: gsr P/S pump on Ek (SOHCD16y8)
The hose that bolts to the top of the pump, right?
If so, nope...mine didn't when I swapped in my b18c into my 97 ex. But hopefully someone can verrify this since I wasn't planning on keeping P/S anyway, so I didn't try too hard to fit it.
Edit: I'll check later and confirm that, I have both pumps(and the hose) so I'll compare them and let you know...
Modified by TophM at 12:30 PM 1/13/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">Will the P/S pump from a 97 gsr hok up to the pressure hose on a 97 Civic Ex? Thanks</TD></TR></TABLE>
Mine didn't. I had to use a 99 Si pump because there was something different on the mounting or the hose size...i forget which. I have a JDM gsr though so it may not apply to your situation.
Re: (SOHCD16y8)
They're different, I compared the two pumps (one from a 97 EX, the other from a SiR-G (JDM GSR)), and the EX pump has two bolts , one on either side of the opening. The GSR pump has the two bolts on either side, but they are alligned towards the bottom of the opening.
like this- EX: -O- GSR: _O_
where the dashes are the bolt locations in relation to the opening(the O).
If it helps you, I can take a picture of the pumps side-by-side tomorrow morning.
devin500
09-22-2010 09:49 PM
hybridej7
07-22-2005 03:56 AM
