Clutch master cylinder bad???
Ok before i get started, my tranny was never in the best condition, would grind 2-3rd alot. But the past 2 weeks a new problem has occured.
When i first drive the car, for the day, it runs great (usually to school 30min away) Well the ride home is another story. Ill be driving, and it almost feels like i lose preasure in the clutch, and from that point on its all down hill.. If im at a stop, its almost impossible to get into first, and when it is in, it shakes violently, like the clutch is grabing but its not. And basicly when driving its really hard to get in and out of gears. Is it my tranny? Or is it my master cylinder?
I checked, and re filled my clutch reservoir, and i toped off my tranny fluid. Im thinking its the master cylinder but i dont wanna go get a new one if its not.
Re: Clutch master cylinder bad??? (JDMTurboCivic11)
check to see if your slave is leaking, and try bleeding out the system, also check to see if you have a leak under your clutch pedal towards the firewall, if there is then most likely master.
GraphiteMW
03-25-2007 09:26 AM
Ri5e
10
09-22-2004 05:36 AM
