just put in synchromesh today......
i just put in some synchromesh today with the hopes that it will cure my thrid gear grind a lil.....i drove it around for a little bit but still same grind....i herd it takes a coulple hundred miles to kick in????
Re: just put in synchromesh today...... (SigleyEK)
It's only a mask for the real problem. It won't "cure" it. Give it a little longer though and it may start to help a bit more.
Re: just put in synchromesh today...... (******)
yeah, it took about 200 miles to start working for me. It may only mask the problem, but it does buy you more time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">yeah, it took about 200 miles to start working for me. It may only mask the problem, but it does buy you more time.</TD></TR></TABLE>
i'm curious... does this actually work that well? i'm kind of thinking of switching from the honda MTF to this.
Re: just put in synchromesh today...... (unrefined7)
if your tranny grinds everytime you put it into a certain gear(s), then it may be a good idea. if you have a healthy tranny, just run honda mtf.
Re: just put in synchromesh today...... (IHateJDM)
What kind of Synchromesh did you buy? Was it the $15 GM Friction Modified? Because if it's just the standard stuff, it's basically the same as Honda MTF.
Re: (SigleyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SigleyEK »</TD></TR><TR><TD CLASS="quote">an auto tech told me it was just as good if not better than GM synchromesh
But there are two kinds of SynchroMesh. The standard, and friction modified. That fluid may be better than the standard fluid, but won't do anything for your grind.
Either way, it's just a band-aid solution. Eventually you'll have to get the tranny fixed.
Re: (AutoXer)
I just put the GM Friction-modified in mine about 200 miles ago. It definitely helped my third gear grind. It only would grind if I would shift quickly or at higher rpms. Now it only does it at reallllly high rpms.
I'm just going to stay out of redline until I can get a new tranny later on.
crazybluecivic
Honda Civic (2001 - 2005)
40
03-01-2008 10:30 AM
when I first start it in the morning it won't go into first gear but after a few minutes it shits fi
piggydog
10-20-2006 05:54 PM
ciRcuitJerk
10-08-2003 06:07 AM
