skunk2 shiftknob (dumb question...searched)
ok so first off this is about the best 50 bucks ive spent. Throws are so much cleaner even before i get the short throw.
but my question is, it comes with a nut...whats it for? i have a suspicion it has something to do with the fact that when you screw it on all the way the shift pattern isnt in the right spot, and if you dont screw it down tight it spins around...
anyone know?
anyone know?
Re: skunk2 shiftknob (killerpenguin21)
You got it right on the money. It is used to make the shift pattern centered. Be careful when screwing down the nut bc it looks like **** if you scratch off the titanium finish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 »</TD></TR><TR><TD CLASS="quote">Throws are so much cleaner even before i get the short throw.</TD></TR></TABLE>
sure they are
sure they are
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 »</TD></TR><TR><TD CLASS="quote">ok so first off this is about the best 50 bucks ive spent. </TD></TR></TABLE>
right on. Now get some ES bushings for the shifter stabilizer.
the bushings are the same for a D or B...well not the 'same'. The D is a two piece that hooks to the tranny, whereas the B is a one piece that needs to be pressed in (can be done by hand)
HT White Ops
A better solution to the nut is this:
Remove shifter console. Get two neoprene washers at a hardware store, put them on the shifter below the threads. Then put your center console and boot back on. Now your boot stays up, and is adjustable.
Then, get some <FONT COLOR="blue">blue</FONT> threadlocker (I cannot stress this enough, the red kind is industrial ****, and you'll be hard pressed to find a man strong enough to ever remove your shift **** ...). Put a couple drops on the threads, and smear it around.
Then just keep wrenching (not litterally, but twisting hard with your hand) your shiftknob down and keep wrenching till it's super tight and the pattern is where you want it. Sits lower, you don't have the stupid nut, and your boot sits flush. Woo.
HT White Ops
Re: skunk2 shiftknob (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">the bushings are the same for a D or B...well not the 'same'. The D is a two piece that hooks to the tranny, whereas the B is a one piece that needs to be pressed in (can be done by hand)</TD></TR></TABLE>
And those are the same how?
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 »</TD></TR><TR><TD CLASS="quote">i screwed it all the way down and it doesnt line up. ill just stick with the nut until my setup is finalized...thanks guys.</TD></TR></TABLE>
Keep threading. You just gotta turn hard.
Re: skunk2 shiftknob (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna »</TD></TR><TR><TD CLASS="quote">sure they are</TD></TR></TABLE>
Yea they are, its a weighted ****
Re: skunk2 shiftknob (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Yea they are, its a weighted **** </TD></TR></TABLE>
and that changes nothing genius
right on. Now get some ES bushings for the shifter stabilizer. </TD></TR></TABLE>
yep you definately need es bushings for the shift linkage...i have factory bend B&M short shifter with the skunk2 **** and es bushings...feels great...just put the bushings on today...helps alot...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna »</TD></TR><TR><TD CLASS="quote">and that changes nothing genius</TD></TR></TABLE>
I'm guessing you have never used a weighted shift ****?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">I'm guessing you have never used a weighted shift ****?</TD></TR></TABLE>
in my vehicle as we speak, and? but enough thread jacking
i dunno how you can say it doesnt change anything...with my stock **** the throws were slow and notchy and once i put the **** on everything became more smooth...but i wouldnt know
