help with my blinker/corners
I have a 96 DX hatchback. My passenger side's corner light stays off when I turn on the lights, but when I signal it works... I'm a noob when it comes to electrical problems so please help!! Thanks.
Re: help with my blinker/corners (steveEK9)
I think the signal bulbs have 2 filaments and most likely the smaller one has burned out. Your fix will be as simple as buying a new blinker bulb... hopefully.
Had the same problem with my eg. I replaced the bulb and still no go. What I found out was that the fuse that bolts up in the engine bay behind the headlight was not secured. I scrapped a little paint off for a good ground and bolted it up. Worked wonders and I didn't have to buy any bulbs.
Bambooseven
03-03-2009 08:40 PM
wlee112
01-10-2006 12:28 AM
