Still no solution to why my car won't start. HELP!!!
Alright, I have a 1999 Civic EX. My car died about a month ago while I was driving. I was going about 25mph and all of a sudden I felt this jerk..........then the car died! I rotated the crank with the valve cover off to see if it was the timing belt........and it's not that. I replaced all the spark plugs..........and it's not that either. My CEL codes are:
1 O2A - Oxygen sensor #1
9 CYP - cylinder sensor
71 random misfire cylinder 1
73 random misfire cylinder 3
I checked to see if the fuel pump was priming when the ignition is turned to the II position and it was fine. Then I replaced the distributor because of the CYP and the car still won't start! When I went to check to see if I had spark by touching the spark plug to metal I had nothing. Why don't I have a spark? It's a new distributor. What could be another possible problem? TIA
Re: Still no solution to why my car won't start. HELP!!! (jus2sho)
try changing the ecu with a buddy that has the same engine and is obd2, your problem could be there, and check all your fuses, its might be your 7.5 backup fuse
Re: Still no solution to why my car won't start. HELP!!! (t3t4delsol)
What fuse number are we talking about here? The only back-up fuse that I see is fuse #19, and that's for back-up lights.
in your engine bay check all the fuses in that box, the ecu back up fuse is in there it is a 7.5 amp fuse, but check all of them,
headrec*
04-04-2013 08:28 PM
ex_ricer
08-14-2008 11:42 AM
JDM-Riders
10-22-2006 05:05 AM
