Help with d16z6
Re: (94ex-vtec)
i thought if oil was leaking it would be a bluish color, and it would come out of other places except the tailpipe, if i do need to change the head gasket anyone know if it is DIY possible or how much the shop SHOULD charge?
Guest
Posts: n/a
Re: (4dooreg11)
It sounds like a headgasket. How mechanically oriented are you is the question? First time changing a head gasket will prolly take about 4.5 hours without any problems. I would recommend doing it yourself as it will teach you a lot about working on your own car. It would be a good idea however to know someone who has done it before just to make sure you get all the timing lined back up right. Its not too bad of a job really just kind of time consuming. A Honda dealership usually charges around $800-$1000 depending on the place and time. Other local shops usually about $500-$700. They have the upper hand most of the time since this is not a job just any average Joe can do.
