MY CARS IN AN ANGLE??...CHECK IT OUT
HEY PEEPS...well i also left a topic about my sidemarkers...well check this...my left side was more lower then the right side...so i got my new tein springs...and yet still its the same problem.....when i installed my springs my shocks kinda are wearin out and dont have much left....do u think thats the pro??? sum1 hit me right side a lil on the bottom under the quarter panel and ran...wat do u think it is???????
Re: MY CARS IN AN ANGLE??...CHECK IT OUT (jdmej814)
you must tighten the suspension bolts while the car is on the ground , not in the air. thats your problem. loosen bolts and retighten on the ground.
Re: (jdmej814)
because if its tightened in the air it will preload the bushings with the susp hanging and not in its normal stance. this has been covered a million times.
Re: (jdmej814)
When you say to tighten the "suspension bolts" while the car is on the ground, specifically which bolts are you referring to? I just got new tokico shocks/tein springs put on my 93 LX and I know the shop did everything with the car in the air.
Re: (93project4)
any control arm bolts and shock bolts. basically if the bolt goes through a rubber bushing it has to be tightened in its resting position.
Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">any control arm bolts and shock bolts. basically if the bolt goes through a rubber bushing it has to be tightened in its resting position.</TD></TR></TABLE>
Did you also check if the ground your car sits on is level? Most garages and driveways are always slanted in some way.
hatcht9x
20
10-22-2008 05:49 PM
ShinotakuX
13
09-12-2007 10:13 AM
ej8123
11
03-15-2007 06:40 PM
