stripped nut on rear disc break
well i just bought rear disc brakes for my EG from a integra....while removing the arm from the hub 1 nut got stripped. the nuts have a star pattern on the top of the bolt....my friend stripped it using the impact gun just trying to blast it off and not ease it off slowly, my question is where can i have find a lug nut remover, i dont wanna cut it off becuz theres no room on the hub, went to sears but only had the impact set for 65.99 not worth it for 1 bolt
Re: stripped nut on rear disc break (nub_pwn)
You are trying to remove a lug nut? OEM size? If so, with a 19mm or a 3/4" (I think) socket and pound it on with a hammer. Take off accordingly.
OR are you trying to take off the UCA from the trailing arm? I used a stripped bolt socket to remove a stripped bolt. Yes, the set can be expensive, but worth it if you happen to run across another stripped bolt.
justYncredible
Suspension & Brakes
05-29-2012 12:13 PM
Thrillahbeeh
05-25-2006 05:33 AM
mstewar
11-13-2003 09:23 AM
