Outer door molding replacement?
Does any aftermarket companies sell the outer door molding replacement for the 92-95 civic hb? The molding I am talking about is found on the outside of the door and meets with the window. The molding runs the length of the door and is covered with rubber with metal underneath. My moldings are showing metal now and tyring to find the cheapest way to replace them. Thank you
Re: Outer door molding replacement? (JohnnyEF)
there was a post on this a few days ago that had places, part numbers, and prices. Do a search on painting door moldings I think. I will see if I can find it for you
Edit: here is a thread about them with location numbers.
https://honda-tech.com/zerothread?id=1561832
Check here for them and shop around
http://www.majestichonda.com
I finally found it here you go this has all the info you need
https://honda-tech.com/zerothread/1777179
Modified by instructor74 at 10:32 AM 10/18/2006
Modified by instructor74 at 11:01 AM 10/18/2006
jeremyrocksursox
03-05-2009 04:49 PM
