How many Synchromesh Quarts?
Gentlemen,
I searched but most threads I found did not seem to apply.
'93 Civic HB CX 5spd.
154k miles. Does not grind, but it's not very smooth when selecting gears.
Time to change transmission oil. Decided to go with Pennzoil Synchromesh Fluid (PN: 3501). I understand it should be between 2-3 quarts, but how many should I put in exactly?
Thank you,
-Walter
Thank you,
-Walter
HT Order of Merit
Re: How many Synchromesh Quarts? (DSMAddicted)
There are two plugs on the passenger side of the transmission, towards the back, somewhat in front of the axle entry. The lower one is your train bolt and the higher one is the filler.
With the car on a level surface, put in 2.5 quarts in the fill hole. Then stick your finger in the hole. If you can feel the fluid there, your good.
Re: How many Synchromesh Quarts? (03akkord5spd)
More like 1.5 quarts for his d-series. Drain the old stuff out. Use a funnel with a long neck and fill it until fluid starts dripping from the fill hole.
Thanks for the tips guys. I am still not sure wether to fill it with 1.5 or 2.5 quarts, I guess I'll just keep pouring until the top filler 'overflows'.
Regards,
-Walter
Regards,
-Walter
Cambo: I had already gotten Synchromesh.
Thanks for the tip guys, the fluid that I found in the tranny smelled like gear oil. I drained it and pumped Synchromesh until it started overflowing. I was able to put almost two quarts.
The gearbox shifts more smoothly now, gears are engaged softly, a definite improvement (daily driving).
Regards,
-Walter
Regards,
-Walter
is synchromesh really good ive been lookin for some tranny fluid and yea ive been hearing synchromesh alot n where can you get it STUPID 3rd gear grind
As long as I dont have to take out any more Metal Gears
Re: How many Synchromesh Quarts? (97civicB18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicB18C »</TD></TR><TR><TD CLASS="quote">is synchromesh really good ive been lookin for some tranny fluid and yea ive been hearing synchromesh alot n where can you get it STUPID 3rd gear grind</TD></TR></TABLE>
At a GM dealer
At a GM dealer
mardymac4244
Honda Civic (2006 - 2015)
11-25-2017 03:58 AM
holmesnmanny
07-14-2016 05:45 PM
