My Cluster Is Possessed
Whats up guys? Im not sure what is wrong with my dash cluster but my speedometer jumps and then dont work. My rpm's work perfect and so does the tem/gas meters but the speedometer wont work and then sometimes it does and jumps back and forth... Any clues on what it could be? loose wire? faulty alarm? or should i take it to honda and have em look at it? I bought an SIR cluster but i dont wanna install it till i fix this problem... One more thing, my entire dash and ac controls don't light up either... can this all be because of the same problem?
thanks guys!
thanks guys!
HT Order of Merit
Re: My Cluster Is Possessed (TheReverseMicrowave)
I had this problem with mine, and it actually turned out to be a bad cluster. Swap it with a friends, if possible, to check.
I've tried that already and continued to have the same problem.. Thats why i dont wanna install the SIR cluster till i solve this... I dont remember it doing this when i bought the car... It wasnt until i had the alarm installed that it started but im not 100% sure on that.... Damn it! thanks though...
speed censor... it happened to my bros car.. easy fix too.. takes like 1 hour to do.. and like 30 bucks off of ebay.. and for the lights its prolly just a fuse.. check under the dash and look at the fuses.. gl
Global Moderator
Re: (chuniepatuni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuniepatuni »</TD></TR><TR><TD CLASS="quote">speed censor... it happened to my bros car.. easy fix too.. takes like 1 hour to do.. and like 30 bucks off of ebay.. and for the lights its prolly just a fuse.. check under the dash and look at the fuses.. gl</TD></TR></TABLE>
One hour to fix a vehicle speed sensor?
Did you drink a 12 pack during the process
30 minutes max.. If that
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
30 minutes max.. If that</TD></TR></TABLE> changing a vss? shouldnt even be that long
I'm having a similar issue but I don't think its the VSS.My Apexi boost controller still reads kph uninterrupted as does my Hondata datalog.I believe its the cluster or the cluster connector.I've been to busy to investigate further,but I am getting better at kph to mph conversion.
Global Moderator
Re: (Spoonspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonspeed »</TD></TR><TR><TD CLASS="quote"> changing a vss? shouldnt even be that long</TD></TR></TABLE>
Come on now.. You left the rest out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">30 minutes max.. If that</TD></TR></TABLE>
Re: (Jimmy)
Ill replace the speed sensor then see how it acts... Once i fix it and i swap to the SIR cluster which is in kph will it function normal or will it be off?
Re: (TheReverseMicrowave)
could also being a wiring problem. i know that some 5th gen civics have problems in the wiring with these speedos. ALSO the circuitry is poorly designed on the back of these clusters. its like paper with copper run through it, then coated with a spray that cracks off.... surely honda didnt think a lot about this one.
Re: (Spoonspeed)
an hour, 30 mins..WHO CARES!
check your grounds, my tach was acting all wacko jumping back and fourth..turned out to be a disconnected ground for the cluster
Re: (ShagPower)
i'm having problems with my cluster as well like at night i'll be driving then the lights in the cluster will jus shut off and if i dun do anything eventially they'll come back on but then shut off again sooner or later or if they do shut off and i switch all the lights off on the car and then right back on the cluster lights will stay on till they feel like shuttin off again
i have the same problem, though mine doesnt have a tach, its the stock dx cluster, i have all the fuses but it still wont lite up and i replaced the wiring in my car (to the dash anyway) and brought all new fuses. not sure if its the sensor or the cluster itself, but wen i buy a new cluster with the tach on it and it still doesnt work, where wud the sensor be located to replace that or is it built in the cluster? O_o
turbo Si
07-09-2006 07:12 PM
MrSmith
12
05-25-2002 01:13 PM
