grinding noise
grinding noise
when i m in the low rpms there is a grinding noise. the clutch does not slip and gears dont grind when i shift. just hate to buy a new clutch if i dont need to. where should i start?
HRD PKR
Re: grinding noise (accex843)
checked ur backing plates on the back of ur rotors? or stuff like that?
mtf low?
where is it comming from? i guess the front?
do u have honda mtf in the trans?
mtf low?
Re: (raphael)
theres no way for anyone to really help unless you have a general idea of where the noise is. it could be a wheel out of balance, or a shot rotor, brake pads. does it make the noise if youre coasting in neutral or only under accelleration. the more details you give the better more helpful responses you will get
Re: (SHG_Wacky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHG_Wacky »</TD></TR><TR><TD CLASS="quote">theres no way for anyone to really help unless you have a general idea of where the noise is. it could be a wheel out of balance, or a shot rotor, brake pads. does it make the noise if youre coasting in neutral or only under accelleration. the more details you give the better more helpful responses you will get</TD></TR></TABLE>
X2
X2
