Help.
Old Feb 20, 2007 | 11:37 AM
Q*Spec.'s Avatar
Default Help.
It's a long story, but I have a 00 civic coupe. You can find pictures of it at http://www.ridejudge.com search by username: JQuizel
If you go there you can see that the suspension is an air-ride system. The air-cylinders are the main problem with the car and I am going to be replacing them. My question is what suspension kit will be safe to drive with being it that the car has 19" wheels. The suspension kit can't be more than 1,000 dollars.
My second question is the engine has broke 100k miles on it and will need to be replaced. I need a fast engine but the catch is that it has to say an automatic transmission. I have a below the knee prosthetic leg and am unable to work the clutch. If nothing else I might just replace it with the same engine and either s/c or boost it. Thanks.
Old Feb 20, 2007 | 11:39 AM
Q*Spec.'s Avatar
Default Re: Help. (Q*Spec.)
http://ridejudge.com/ridedetails.asp?RideID=15390 Thats the direct link to pictures of the car.
Old Feb 20, 2007 | 11:46 AM
sohcvtec1995's Avatar
Why would the motor need to be replaced? did it blow? if that is the case you can really do any motor. seeing that 99% of honda motors have a auto and manual transmission also are far a s a safe suspension i would stick with the air ride. 19's are some big rims, and it will be hard to find a compatiable suspension
Old Feb 20, 2007 | 11:49 AM
Q*Spec.'s Avatar
Default Re: (sohcvtec1995)
No you dont understand. The air-ride suspension is screwed up and will definately be coming out of the car. We have taken it to three places before and none of them could fix it. I just want a simple suspension system that will be safe to drive on. Doesn't have to be straight from TEIN or Spoon.
The motor is working fine now, but I'm not sure how long it will last. That question was more for future reference. So the RSX-S engine, or GS-R engine will be okay with the auto-transmission?
Old Feb 20, 2007 | 03:24 PM
fdavie's Avatar
Default Re: (Q*Spec.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Q*Spec. &raquo;</TD></TR><TR><TD CLASS="quote">The motor is working fine now, but I'm not sure how long it will last. That question was more for future reference. So the RSX-S engine, or GS-R engine will be okay with the auto-transmission?</TD></TR></TABLE>
The motor will probably keep working fine for another 100k miles if you're taking care of it. Honda motors in stock form are pretty close to bomb-proof.
Old Feb 20, 2007 | 04:16 PM
Q*Spec.'s Avatar
Default Re: (fdavie)
The engine has a header, CAI, and I believe the exhaust system is cat-back. But just for future reference, will the GS-R engine and RSX-S engine work with the automatic transmission?
Modified by Q*Spec. at 5:33 PM 2/20/2007
Old Feb 20, 2007 | 04:21 PM
SirRevvs's Avatar
As far as your suspension, just get some H&R springs or something with a low amount of drop or just use stock civic suspension.
And your engine should last a good while if you maintain it so I wouldn't worry about having to do a swap unless you just want the extra power. It that case I would reccomend an Auto B16 swap or LS. I wouldn't reccomend putting a GSR on an auto trans.
Old Feb 20, 2007 | 04:26 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Q*Spec. &raquo;</TD></TR><TR><TD CLASS="quote">The engine has a header, CAI, and I believe the exhaust system is cat-back. But just for future reference, will the GS-R engine and RSX-S engine work with the automatic transmission?</TD></TR></TABLE>
No B- or K-series engine will work with your D-series automatic transmission. Your best bet is to build another D-series on the side with the intention of turbocharging it down the road. That way, you can keep your current transmission and get some speed out of the deal without sacrificing ease of use.
As far as suspension goes, how stiff do you want it and why are you married to the 19-inch wheels? Unless your dead grandparents bought them for you at graduation, I'd be ditching that **** faster than you can say, "lower unsprung weight what!?"
Old Feb 20, 2007 | 04:35 PM
Q*Spec.'s Avatar
Default Re: (Archidictus)
lol, like i said, its a long story. and no i didnt steal the car. has anyone gone to the link???
Old Feb 20, 2007 | 04:41 PM
crispy93's Avatar
just a quick question...what kinda car IS that? i know its a honda...but i cant tell haha
*edit* just kidding...i just read the first part of it...that doesnt look like a 2000 though...and good luck finding suspension thatll work with 19 inch wheels...
Old Feb 20, 2007 | 04:49 PM
-JSpecEk*9-'s Avatar
Default Re: (crispy93)
Old Feb 20, 2007 | 04:57 PM
mugenEGG's Avatar
Old Feb 21, 2007 | 03:57 PM
Q*Spec.'s Avatar
Default Re: (mugenEGG)
lol, okay so you see the car.......any one know of a suspension (aftermarket) that will work with 19"s?
Donutyea
Honda Civic (2001 - 2005)
Feb 12, 2009 04:55 PM
redegboosted1
Jan 8, 2009 01:14 PM
jdmbreed
Oct 5, 2007 08:09 AM
ProjectJDM
Apr 14, 2005 10:39 AM
SpyderZEX
Jul 25, 2004 11:30 AM
