Timing Belt issue PLEASE HELP
Colorado <3
Does one of you guys happen to have a step by step install on putting a timing belt on a b16? I have a gsr bottom end with a b16 head on it.. I want to make sure 100% that i am doing it right Thanks so much!
Re: Timing Belt issue PLEASE HELP (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Also keep in mind that you can't use a B16 timing belt with that setup. </TD></TR></TABLE>
yeah what ever water pump you are running is what timing belt you need to use. but if im not mistaken the b16 and gsr have the same size pulley???!!!
Darth ModerVader
Re: Timing Belt issue PLEASE HELP (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution »</TD></TR><TR><TD CLASS="quote">yeah what ever water pump you are running is what timing belt you need to use. but if im not mistaken the b16 and gsr have the same size pulley???!!!</TD></TR></TABLE>
I was referring to the taller deck height of the GS-R block, which therefore requires a different belt than the B16A.
I was referring to the taller deck height of the GS-R block, which therefore requires a different belt than the B16A. </TD></TR></TABLE>
thats what i was stating above better have some arms on you cause you can do it but its a bitch
Darth ModerVader
thats what i was stating above better have some arms on you cause you can do it but its a bitch </TD></TR></TABLE>
I wouldn't suggest trying to force a B16 timing belt on a GS-R motor, if that's what you mean.
zach1288
05-08-2007 06:04 PM
racingant
12-17-2005 04:23 PM
