How to remove moisture from the inside of my tailights?
Like the topic says, I took my car through the car wash a week ago, and theres still moisture in my tailights, and I was just wondering if theres an easy fix to dry it out inside of there?
HRD PKR
Re: How to remove moisture from the inside of my tailights? (carboncivic)
sit them in the sun.. or u can maybe sit them infront of a light. just dont let them get to to hot.. and then use clear silicon to re seal them!
Re: How to remove moisture from the inside of my tailights? (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">sit them in the sun.. or u can maybe sit them infront of a light. just dont let them get to to hot.. and then use clear silicon to re seal them! </TD></TR></TABLE>
thanks, i need to do this on my tails
Re: How to remove moisture from the inside of my tailights? (alacard)
get stock lights. i hope your oem ones arent leaky
reseal them if you want to keep them.
Re: How to remove moisture from the inside of my tailights? (platinumx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 »</TD></TR><TR><TD CLASS="quote">get stock lights. i hope your oem ones arent leaky
reseal them if you want to keep them.</TD></TR></TABLE>
not sure about the OP, but my stocks have water in them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">
not sure about the OP, but my stocks have water in them.</TD></TR></TABLE>
Yep, they were find just until a little while ago, then i noticed moisture in BOTH of them...
HRD PKR
some leak.. put the under a heat lamp. dont let them get to hot! and then re silicone them with clear silicone.. jezz stock headlights/tail lights do it all the time
