QUICK QUESTION! (Rear Coilovers)
1999 civic. I took out the top two bolts and now the bottom one that connects the shock to the (thing). lol
There is way to much pressure for me to pull the shock out... any tips/hints?
HT White Ops
Have someone stand on the brake knuckle and hop up and down while you jimmy the shock out of the way.....
Or do it the right way and take the LCA bolt out of the brake knuckle and drop it down.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Have someone stand on the brake knuckle and hop up and down while you jimmy the shock out of the way.....
Or do it the right way and take the LCA bolt out of the brake knuckle and drop it down.</TD></TR></TABLE>
wheres the lca bolt?? :/
HT White Ops
Well, considering there's only three bolts on your lower control arm .... one is connected to the shock fork, one is connected to the subframe of the car ..... that only leaves one option.
Re: (Eran)
opps.. i didn't look hard enough i guess... ok so i located it, now i can not turn it... is the nut welded on like the other one on the bottom of the shock? i tried to turn it and no luck.. then i tried to use the hex thing and no luck...
HT White Ops
Re: (blackrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag »</TD></TR><TR><TD CLASS="quote">SOLVED IT! THANKS EVERYONE </TD></TR></TABLE>
Glad to help. I've put more wrenchtime into my suspension with all the times I've changed it than I have to any other part of my car, including my swap
In fact, I'm crawling under my car this Friday afternoon, and probably won't come out except to drink and **** till I'm done. Front and rear swaybar installs, replacing front LCA, and subframe brace install.
HT White Ops
Re: (vtecftw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecftw »</TD></TR><TR><TD CLASS="quote">remove the LCA bolts
( lower control arm)</TD></TR></TABLE>
Congrats on regurgitating information an hour after he figured it out.
Re: (Eran)
Congrats on regurgitating information an hour after he figured it out.</TD></TR></TABLE>
haha just had too laugh at that
Re: (vtecftw)
thanks!
thanks!
gitrdone
Honda Civic (2001 - 2005)
10-05-2007 07:56 PM
