ht check engine light on ek
hey guys tonight i was planning on taking off the stock airbox on my ek and im wired for obd2 ........ i disconnected one of the wires to get it off then my check engine light came on the car still runs the same but i plugged everything back in and its still on??? what should i do? thanks
Re: ht check engine light on ek (zcrx2006)
An easier way is to look for the fuse panel in the engine bay on the passenger side and remove the 7.5 amp fuse for a few minutes. Replace and see if the CEL goes away.
If that doesn't work, go to your local automotive parts store and ask to loan out an obd code reader...
just disconnect your battery for 15mins then reconnect and let run for 15 mins without give it gas. i think would be easy. unless you want to go to a shop and get it scaned for hella money.
BettyBlue21
07-04-2018 08:46 AM
hondaracin24
10-19-2004 09:22 AM
