# 2 missfire
# 2 missfire
I swaped k20 into my 96 civic coupe,i fabricated 4-2-1 header & air fuel ratio sensor was installed on 2, iam not sure if that maters or not. I have no cell codes.
Now when i took diagnostic readings the AFR was negative -5 to -6.5 & # 2 missfire.
What can cause these readings,the car does not start right away??
Unceasing Measure
Re: (ngq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngq »</TD></TR><TR><TD CLASS="quote">no k-pro,oem prc ecu</TD></TR></TABLE>
Until you have K-Pro, your swap really isn't finished. I suggest getting some cash together and making it right before you concern yourself with a random misfire in one cylinder. The starting problem is almost positively due to the ECU and chassis discontinuity.
Than you for info. but can i get such problems from instaling the AFR in the wrong place.
