fuel injection cleaner....
Just curious/woundering what type of fuel injection cleaners additive do most of you guys us on your honda(s)? Brand wise or whatever. Or is there a certain brand or certain kind that kinda does the job better than the other or does it all work the same? Just curious because I wanted to go and buy a bottle but couldn't decided on which brand. TIA
Re: fuel injection cleaner.... (crashzerothree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashzerothree »</TD></TR><TR><TD CLASS="quote">I use gumout
As do I.
As do I.
ditto here... all though it will never be as good as a professional cleaning.
Re: fuel injection cleaner.... (Relic1)
I either use the gumout or redline as regular routine maintence every other oil change. I'll be using seafoam though when I install my injectors (they were used for about a year).
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">i trust redline stuff.
i've heard good things about lucas as well.</TD></TR></TABLE>
never tried it, but it' only like 2-3 bucks...maybe next time I will
Okay cool thanks...I'll have to look around again and re-read the labe and etc. and compare otherwise guess I can try the "gumout" and look at the red line stuff, but thanks guys
Darth ModerVader
Re: fuel injection cleaner.... (JDMegCoupe)
If you really want to ensure your injectors are performing as well as they can, I'd suggest sending them out for professional servicing. It's not terribly expensive (around $15 per injector), and they should come back in very good condition:
http://kgparts.com/index.php?page=fuelinjectclean
http://www.cruzinperformance.com/injsteps.html
My injectors are 15 years old. Would a service cleaning like that be recommended? Car runs super peppy but still wouldnt mind having them cleaned since I never knew the service wasnt that much money. Maybe that could solve my horrible fuel economy problem that NOTHING else has fixed.
Darth ModerVader
Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">My injectors are 15 years old. Would a service cleaning like that be recommended?</TD></TR></TABLE>
Sure, especially considering how reasonable the cost is. You'll also get a good idea of the condition they were in, since most shops will provide before/after performance data.
Re: fuel injection cleaner.... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If you really want to ensure your injectors are performing as well as they can, I'd suggest sending them out for professional servicing. It's not terribly expensive (around $15 per injector), and they should come back in very good condition:
KGParts is running a special for HT members. https://honda-tech.com/zerothread?id=1951304
