My engine has detonated!!
I recently bought a Hondata ECU chip and installed it on my Honda Civic 2000. The car has a Roots supercharger w/ a cooling system. I haven't taken it to the dyno in a week, and I have been thinking it was the problem. But I took it to the track and my engine detonated. I have no idea why this happened. Any suggestions?
**note** it has been detonated before, but that was becuase I never replaced the O2 sensor.
Re: My engine has detonated!! (ExtremetorquE)
o2 has nothing to do with detonating. What type of gas are you using, whats your compression, how much are you boosting? More then likely your running the wrong plugs and bad gas if your detonating all the time.
If your engine was high compression I'm assuming, and you used regular, that caused your detonation. High compression engines require premium.
Re: My engine has detonated!! (EM1_ChRiS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS »</TD></TR><TR><TD CLASS="quote">If your engine was high compression I'm assuming, and you used regular, that caused your detonation. High compression engines require premium.</TD></TR></TABLE>
ooh, thanks, i really did not know that. look at the sign, it says what i am
whos the n00b
whos the n00b
ElCapoDonVito
02-24-2017 05:02 AM
b18LS
07-23-2007 10:14 PM
caliprelude3087
11-08-2004 05:46 PM
