CX to DX
CX to DX
Hey guys im swapping a DX engine into a CX... I know im in deep. I got the computer and all the other stuff for it. im using the original harness from the cx. Everything matches up perfectly. The car STARTS and then boggs out if I dont give it gas passes 2krpms. I checked the codes and it ran eather a code 6 or a 16. 6 is o2 sensor and 16 is fuel injector... does this sound like a what could be giving me problems. An help would be cool.
New User
Re: (PointA2B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PointA2B »</TD></TR><TR><TD CLASS="quote">On a DX is there a MAP scerwed to the firewall??... Will the car run without
you are right
dx - map on firewal
cx - map on throtle body
car will run very shitty with no map
i have done this swap befor and what i do is use the cx harness and a d16z6 throtle body that has a map
the cx throtle body is to small for the dx mainfold and will not bolt up
if you used the cx harness just get a z6 tb
if you used the dx harness you can take apart the cx harness and pin the sensor plug to the dx harness
hope this helps
you are right
dx - map on firewal
hope this helps
New User
Re: (PointA2B)
you should have a plug left over by your "throtle body" that is for your map sensor
you need a d16z6 throtle body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson »</TD></TR><TR><TD CLASS="quote">i have done this swap befor and what i do is use the cx harness and a d16z6 throtle body that has a map
the cx throtle body is to small for the dx mainfold and will not bolt up </TD></TR></TABLE>
if you still dont know what i am talking about search and look up throtle body and d16z6
Re: (williejohnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">i though cx and dx were the same, just the dx came with ac?</TD></TR></TABLE>
No, the CX is shittier () and has the D15B8 which is an 8 valve POS.
The DX has the D15B7 (which is a 16v motor). I am 99.9% sure the B7 uses larger injectors than the B8, though I'm not completely positive.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
The DX has the D15B7 (which is a 16v motor). I am 99.9% sure the B7 uses larger injectors than the B8, though I'm not completely positive. </TD></TR></TABLE>
Sry i was referring to 96-00 models. Same deal though?
New User
Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">Im pretty sure that ground goes to your fuse box by the battery. It looks like the one of the two that go in there. </TD></TR></TABLE>
yes i think so to
yes i think so to
Quick update... That ground wire was causing major problems. My car finally runs. BUT... the Map sensor in the TB screws up the car when it runs, basically the car runs with the MAP unplugged then when its plugged it bogs out... Jeez this is getting ridiculous. Need some help again haha
sleepydragon636
11
04-21-2019 06:09 AM
