Speedo not working
Speedo not working
This is on a 98 ek with a b16a. The tach, temp and gas gauge are all working on the cluster however the speedometer isnt working and vtec is not engaging. I checked the fuse for the VSS and its fine. I saw that the sensor pluge into a piece that is screwed into the trans. What is the next step changing that sensor ? If so what part do i get because no honda here carries stuff for a b16 vtec del sol.
Re: Speedo not working (kornerk12)
you can search here and the part will be used, and cheap. Im not sure on B series but the vss on d-series are intercgangeble if they are AT or MT 88-00 i BELIEVE. ill search for you and find a deffinate answer on your b16 and see if i can find one for you..
i <3 adderall
EDIT: maybe it is by obd-#s? still searching..
Modified by platinumx6 at 7:25 AM 2/21/2007
i <3 adderall
yitbos1992
03-11-2006 09:48 AM
~~~InNeEdFoRsPeEd~~~
07-03-2003 08:40 PM
