wire harness B series
Re: wire harness B series (fnkrew93)
just take out all the loom and move all the plugs and put them where they suppose to be, then re-wrap it. only one you extend is the IAT sensor
1 Post
in my case, I only had to extend 4-wire O2 sensor wires, VTEC solenoid, VTEC pressure, and add knock sensor wire. as for the IAT, I just undid the wrap and pulled it up so it could reach the sensor. if you plan on using some sort of standalone or chipped ECU(with programs such as CROME) you can get rid of knock sensor and more.
hope this helps
hope this helps
Re: wire harness B series (hoya_10fintec)
just take off some of the tape that is attached to the plastic covering on the wires..it will extend the wires..i used little tags on each sensor and made it so much easier to swap it over
Re: wire harness B series (DETALZ)
Detalz, hit me up about the fat five rims. I can pick them up asap. aim:smartbabocom or email me at johnjbrock@hotmail.com
RVMIRXZem1
11-11-2018 08:15 PM
