fuel pump
fuel pump
everyonce in a while ill start my car and it will die right out, ill click it over once the next time and i wont hear the fuel pump prime, wait a little bit then it will start right up, it will never die while i am driving no cel, all fues and relays are good, the motor is b20 vtec in 1992 eg vx thank you.
Re: (19992civichatch)
i have the same problem, amost exact exept i have a 94 coupe with 1.6l vtec d16z6. can any one help us out or had a problem simalar
any one?????????????????? no one knows nothing, not a guess, simalar problem. you guys can tell me that no one has had a fuel pump problem or a fuel prob. any one ????? taking any ideas
Location: Why so you can pretend like youre interested, FL/OK
Re: fuel pump (19992civichatch)
I've been experiencing similar issues. I've switched out the main relay with another I had laying around. No fix. I've then tried to switching out the fuel pump with another I had, no dice. I'm going to see if I have any ecus laying around if not I'm going to have to get out the multimeter and test. It's completely random and will happen while the car is driving. I'm going to browse thru this thread then see if I can get a fix before the weekend otherwise I'll be troubleshooting.
https://honda-tech.com/zerothread?id=1852441
sorry about bumping so much but when ur pulling out in to traffic and ur car will die out it sucks lol tryed a new relay still smae **** doesnt happen a lot bt i jsu twant to no what the problem is
Re: (diLLy)
it happends to me about once or twice a week but with mine it only happens when the engen is warmed up. i was just resurching it on google and many other people have the same problem. one person wrote that they cleaned there igniton conectors (were the key does) and that fix it for him. anthor person said he tryed replacing pump relay and nothing, he found out that the harness for the pump was lose. or some one said that if it has pressure already on start up it will not prime. i went out and looked at my relays and one was alittle lose so i pushed it in. i dont know if it fixed it, havent drove it yet. sorry for the novel just have a lot to say
Re: (94hondacivicvtec)
how i start mine is turn the ignition on for 2sec and waight to hear the pump prime if it doesnt than turn off and repeat. some times you have to let it set for 1 1/2 for it to work. how offen does it happen to you and how do you restart your car?
just found this thread might help since no one else has ideas https://honda-tech.com/zerothread/1483855
i jsu tlet it sit for a minutes turn the key to hear if it primes if it does i let it sit i think mine happend when it was warm to and mine happend any way from 3 times in a round and soemtime it wont happen for a month
sounds like you got the same problem i got if you figure it out post it. i'll do the same. i'll probley look in to it in a few weeks and start trouble shooting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec »</TD></TR><TR><TD CLASS="quote">it happends to me about once or twice a week but with mine it only happens when the engen is warmed up. i was just resurching it on google and many other people have the same problem. one person wrote that they cleaned there igniton conectors (were the key does) and that fix it for him. anthor person said he tryed replacing pump relay and nothing, he found out that the harness for the pump was lose. or some one said that if it has pressure already on start up it will not prime. i went out and looked at my relays and one was alittle lose so i pushed it in. i dont know if it fixed it, havent drove it yet. sorry for the novel just have a lot to say </TD></TR></TABLE>\
dude, that sounds identical to my main relay problems. you should really check that out. when the main relay is starting to go bad, it will work sometimes and not other times. i cant remember if you said you replaced that or not, but if you havent, you should definately try that before troubleshooting everything else
Re: (alacard)
i really like your sig alacard. i think they should all die too. i havent replaced **** in it. havent done any thing but restart it. i will try that but i'll have to waight a month to see if it works. it only happens once in wile. thank you for your help
AcidFr33ze
08-07-2005 10:21 AM
