obd2 ... 2 o2 sensors..?
i did a b20b swap into my eg coupe... im running an obd2 ecu (with 1-2 adapter) and motor.. its throwing a CEL.. and i think im supposed to be running 2 o2 sensors.. is this correct?
if i am.. where do i add one in onto the harness?
Re: obd2 ... 2 o2 sensors..? (stratedrm)
i also have the option to run a obd1 ecu.. if i do that what would i need to change to make the motor run correctly?
just swap in the obd-2 ecu and it wont have a code. motor will run the same. there are many ppl using obd-2 motors with obd-1 ecu, runs the same
the obd1 ecu causes a varying idle and rev... it runs just fine on the obd2 ecu.. i drive it around daily.. but i wanna try to kill the CEL if i can
strictly.business
11-25-2006 09:05 PM
Bimmerman
05-25-2005 02:16 PM
