Can you run a walboro 255 intank on a stock internal motor..??????
I have put this in my car and it would start then die, I have a b and m FPR adjusted to stock settings but still curious if it should do this
Ek Forever y0!
Re: Can you run a walboro 255 intank on a stock internal motor..?????? (4gencivicef9)
If your motor is stock leave the stock fuel pump.
Getting more fuel doesn't do **** without getting more air.
You're car dies likely because your over saturating it with fuel
Re: Can you run a walboro 255 intank on a stock internal motor..?????? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">If your motor is stock leave the stock fuel pump.
You're car dies likely because your over saturating it with fuel</TD></TR></TABLE>
werd
werd
Ek Forever y0!
Re: (Elevorett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elevorett »</TD></TR><TR><TD CLASS="quote">no, you will not over saturate, because that is what the fuel return line is for. any excess fuel will simply drain back into the tank.</TD></TR></TABLE>
The fuel return line can only return so much. Have you seen how narrow that line is?
Re: (ek forever guy)
The fuel return line can only return so much. Have you seen how narrow that line is?</TD></TR></TABLE>
Naw, it needs an assload to "overload" the fuel rail. It'll all drain back to the tank if it's only a 255.
@ OP:
If it's the stock motor it's completely unecessary. Though you won't have any problems caused by it as long as you adjust the FPR to be to its stock pressure range.
@ OP:
Re: (Syndacate)
you'd be surpised how much a 255 walbro can put out.....my old car was boosting 28psi on a 60-1 turbo and it was still running rich....they put out alot of juice... id suggest downgrading back to stock or if you really want to put something, run a 190 Walbro instead....
Another option is simply just run slightly bigger injectors and keeping the stock pump in....
trooper0641
23
04-06-2005 12:51 PM
